Mark300zx
1,454
8
Surrey/SW London
Went to Elite to get alignment done, they adjusted the wishbone and subframe to the max and the camber was still out of spec, -2.0 OSF and -1.3 NSF.
How can I get it back to what it should be?
The guy at elite said it is probably the shocks going that is causing the drop in the suspension/camber. Top mounts seem a bit extreme, I am surprised there are no plates made to adjust the camber!
Just replied in your other post?
If your suspension is standard and wont come into spec then something is either worn or bent. Id probably change the wishbones and all bushes first.
