lcr front splitter
andyc58
71
I could some one tell me how to take it off as half is now hanging off due to the load off snow we had over night and trying to bloody drive to work.Will i have to jack car up to get it of.
PSX
271
It simply clips in around the sides with push-tabs (horizontal). To remove the centre 'pillars', apply firm downward pressure with the palms, employing a rocking motion if need be to free them. Loosen the sides first though
Hope this helps
Alex
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
This really is a 5 min job just lock some self gripping pliars on the outer most part first and then tug away and then move further into the centre. leave the two centre clips till both sides are out. then pull the centre clips ou by pushing down to the floor
EmDee
Omnishambolic
Horsepucky!
This took me ages and a lot of swearing, obviously yours was never on properly :p
you need to pull outwards on the sides first and then push down on the middle two prongy bits once the sides are not attached. I parked up on a curb and stuck a box wrench in the gap and jumped up and down on it for 15 minutes shouting, but you may find a more refined approach.
