Not one of these specifically ....they've come on a bit recently - in the past, the best you could hope for was an Aux input
I've fit Connects2 boxes before - biggest issue you'll have is finding somewhere for the box (hopefully it'll slide down the glovebox side of the centre console ok if the loom's long enough, and you'll be able to poke the iPod cable down behind without having to take the glovebox out)
There are a number of guides on here if you get stuck - search box in the top, right corner of the page - but you can remove the radio using a couple of strips of old credit-card/broken hacksaw blade/radio removal tools in those two slots at the botom....jostle it around a bit till you can grip the edges (it's so much easier with a tape player cos you can just poke your fingers in the cassette slot!) and pull it out.
The blue plug that comes with the Connects2 box goes in the back. Feed your wires somewhere sensible* and push the radio back into place till it clicks.
* some Connects2 boxes have a procedure to follow with regard to what order to connect things and when to power them up, so follow the instructions carefully
