This problem started only a couple of days after getting the car. Basically between about 2-3000rpm I am losing boost pressure as you can hear it gushing out from somewhere, above this it is not quite so noticeable. I thought it was one of the intercooler hoses so I got a second hand set which I fitted today and sadly the problem is still there. I also took the recirculating valve off and this is in good working order and I checked just about everything else I can see and found nothing.
I ran a vag-com on it and the only code that came up was excessive engine speed exceeded (Warranty void) or something like that. So now I have next to nothing to go on as to what to check next. Any advise guys or people who have had the same problem?
