calvR
378
Kent
My lcr has developed the most annoying and loud vibration coming from the behind the dash area.
It makes the noise whenever I accelerate then goes wen off throttle and cruising along.
Anyone else experienced this? I wonder if its to do with the resonator that is meant to bring the induction noise into the car?
If I can't find it I'll have to take it in to dealer as I can't live with the noise! :cry:
Sounds like it could be the speaker than makes the noise
This is what I was thinking as a couple of times recently it has sounded different wen accelerating, but only briefly then bac to normal. Now its vibrating everytime.
Mines has rattles from the dash, nothing too annoying, working on assumption its Seat build quality!
n75 boost valve makes vibration noise on bulk head pass side there is a modified pipe
from air box to valve have a look at that.plus have a look at clutch pipe have had that come out of clip on gearbox
Thanks, Ill check these out when I'm home, its good to start ruling things out
