Leaky door sill ??
Joe K
52
Hi guys,
I seem to have a leaky door sill drivers side . Its always wet on the step .
Is this a common fault and just a case of replacing it ? How much are they ?
Cheers Joe
Joe K
52
http://www.seatcupra.net/forums/showthread.php?t=44216&highlight=leaking+seal+guide
Check that thread out.
Mine were the same, its the ancillaries panel on the inside of the door, you need to re-seal it as the rubbish gasket always seems to leak on the leons and toledos. I re-sealed all of my doors not long after getting the car.
Check your floor, might be damp.
Loads of threads on here if you search for them
I found the thread but mine is leaking in between the two lower seals only and my floor is not damp :confused:
Tpot
If its not causing a problem then you could leave it, however I think you can cut a slit in the seal that runs along the sill. I might be wrong here but I'm sure someone has done it on here and had some success.
AntneeUK
2 Wheels 2 Many
Mar 8, 2009
1,491
Nottinghamshire
I have the same thing. I find the seal that attaches to the front of the rear doors is loose. When I open the doors after it's been raining, the water has collected under the door, on the sill (if that makes sense). The wife's 1.4 does the same thing.
