Led rear lights giving dashboard warning
Nov 3, 2024
Hi I have a 2011 1.4 3dr ibiza. I have recently replaced the rear halogen lights with the "tick" led ones. They work 100% however I am getting a lighbulb warning on the dash now. I have vcds and cant see where to fix this in the coding . It seems its not possible. Has anyone else done this and found a fix? Any help greatly appreciated
cairus
1,640
571
You need someone who can read your lighting configuration from the BCM, edit it and then import it again. I don't know of any solution with vcds. vcp should also be able to do PQ25.
cairus
1,640
571
vcp is a useful software for the vw group. bcm is the control unit that manages the lighting. PQ25 is the platform on which the vehicle is built.
