philiplgbennett
58
West Sussex
I've had a problem with my 130 TDI temp gauge not moving above 60 (ie not moving at all) under most driving conditions.
I took it to the local garage and they have replaced the thermostat, red coolant, temperature sensor and water pump (along with cambelt).
After all that (the usual), the only way I can get the temp dial on the dash to move is do 70mph / 2k revs for a decent distance along the motorway. As soon as I slow down, the temp drops. I've not heard the fans kick in for months and the fuel economy has dropped through the floor as it's never getting hot.
Garage said some of the pipes aren't even getting hot until they give it a really fast idle.
I've seen on other forums that it could be the brand / make / model of thermostat causing this and to use specific German / Vag thermostats ?
It's an 04 plate car so I don't want to take it to a specialist, any ideas would be welcome to get her hot and economical again.
cheers, Phil
We replaced the temperature sensor due to it not functioning even when stationary on a fast idle and the engine hot, after replacing the sensor it showed temperature change however on road test the temperature went back down indicating the thermostat is possible stuck open and not maintaining engine temperature, as advised and quoted we would recommend this to be done as this is the only component that regulates engine temperature.
Hope this makes sense, unless the temperature gauge doesn’t move at all anymore even when stationary on a fast idle it may have a bad sensor?
From experience when it comes to replacing thermostats and coolant temperature sensors it's best to stick to genuine VAG parts as aftermarket ones are notoriously shite.
Sent from my SM-G986B using Tapatalk
My momey (if i had any) is on the stat.
That's a pain, they only replaced it two weeks ago. I'll ask if it was a genuine part or not. The invoice has it down as £12 + vat for the part.
I can't tell you how much I've spent on this car in the last six months ? and it's done 245k, should be retired by now ...
You dont need to mate.
We all have the same financial drain ?
Mine isn't even a fancy one..... had a new clutch last year, cambelt and water pump this year, new rear shocks, wheel bearings, i can't even list the rest.... she's not even worth what it cost to get the cambelt done... :rolleyes: I do love it though. The only thing that's a slight concern is whiny gearbox but it changes gear smoothly and still drives ok for the age and miles.
I would say thermostat
I fitted a cheap Circoli one to a 320d years ago. It lasted all of a couple of weeks
Buy genuine
Reactions: jcbmally
I despise Circoli parts, I'll never forget having to change the water pump on one of mk3 Golfs 3 bloody times in about 2 months as the poxy things kept falling apart or leaking.
Remember OEM genuine parts are usually manufactured by other companies, such as Bosch. VAG haven't built a thermostat factory for themselves. So if you can find an aftermarket one that works you're laughing.
Febi Bilstein coolant sensors work fine:
Meyle thermostats work fine:
Both have been in my car for over 2 years. Febi Bilstein is definitely an OEM manufacturer for coolant sensors - I suspect plenty of VWs have left the factory with them installed.
If you want direct from Seat though look here:
If you can find em you're laughing, as you say they VAG don't make these things themselves and often it's little more than the same part shoved in a box with a Seat logo on instead of Febi.
Stuff is usually mega cheap through AutoDoc, shipping can take a while sometimes tho.
Is autodoc not Germany?
So could now facei mport taxes due to Brexit. Just a thought
So here's an update. Drove it at 60mph in 5th to get the temperature up and the needle did move but only to 70 Deg or so. Decided to switch the heater off (I have it on all the time) and the needle gradually went up to nearly 90.... I'm going to drive back at normal speeds in 6th...
Does that give any clues ?
