Leon clutch problem
Paradigm1
Leon 2003 1.4
Hi guys,
I've read through the sticky about the common pedal problem but this is a little different.
Went out to the car this am to find the pedal on the floor so pulled it back up by hand & it's now jammed solid in the up position, can't move it at all.
I drove it last night & no problem so I can only assume it "went" as I parked.
To make matters worse it's parked pretty much up against a wall so I can't open the door fully to have a proper look. I can't see any plastic in the footwell so I fear it's something more expensive :cry:
Any ideas?
Darrenleon54
Sounds like the. Master slave cylinder has gone. Or it may need to be bled. Also check the brake/clutch fluid it may be low.
A new slave cylinder is about 30quid from gsf parts or eBay.
Darrenleon54
If you can get it bled that May fix the problem. Sometimes the pressure is lost or a airlock gets in the system causing the pedal to drop.
I had it on a vw bora and got away with bleeding the msc. Be careful though as the bleed ipe can sometimes sease and snap when you loosen it!!
kr1s77
203
Birmingham
have you had a close look at the pedal, just to check if the master cylinder rod has come out of the white clip and got stuck. this happened to me the other day.
Paradigm1
Cheers guys,
I'll have a look when it stops raining (if it stops raining).
lovesabitofvag
29
i had exactly the same problem a few weeks back, i feared the worst but was a simple fix after, turns out it was because my rear pads were so low it dropped my brake/clutch fluid below the lowest limit in the reservoir, apparently this can cause the pedal to hit the floor too
