leon cr fr tdi 170..problems from new!!
richandbecks
SOON CANDY WHITE FR TDI..
Jun 10, 2011
89
havant area...
As the above........
what problems have u had with the car since u owned it from new or being second hand!!
interested in the cr engines preferably!!!!..........but your welcome to post pd problems. :)
thx
OLDOILER
1,292
Wiltshire, UK
Having had two 170 PD engines the CR 170 is defo the better lump [ least it was designed around the DPF and not the otherway round!] quite a smooth acceleration profile and can be more economicalat speed, should see 40/53mpg at 80mph and about 35 using over 4k rpm.................
jezyg
2,330
28
My CR FR never missed a beat was spot on always started first time and ran as smooth as silk. Only felt slightly rough when DPF was on regeneration.
tony323ci
Lovin' it
May 15, 2011
975
Nottingham
CR FR just over 7k miles spot on only fault water leaking in the bonnet bulkhead and wetting the sound proofing known issue easily sorted under warranty
That and the front centre arm rest should be standard :)
LeonFRDave
78
Bristol
I've had a few problems with mine, first was a boost leak soon after I bought it (10 months), next was a dash rattle. Both were sorted by the dealer under warranty. Then more recently it's been stuttering under low loads - thought to be a software issue - now sorted (I think), then finally I had turbo actuator failure - again sorted under warranty (albeit after a few false starts).
On the whole I'm pleased with the car, I love the way it looks, and drives, the only remaining niggles are a few interior rattles which I can live with.
Hoping that's all the niggles out of the way now.
richandbecks
Jun 10, 2011
89
havant area...
do u have pd or cr?
chris2407
I have now done 16,000 miles in my cr 170 dsg. I have had two new radiators fitted under warranty due to coolant leaks although the garage think the first new one wasn't fitted properly hence the need for another after the original leaked. I have had no problems with anything else and the dpf regen light has never come on.
Websta
136
Ive had the car since may, done 6.5k and had no problems what so ever! YET
No problems with DPF and not had a regeneration or anything....
Scooby250
111
Colchester Essex
I have had my cr for about a month and a half now and I have had no problems so far.
The car has done 32000 miles and the previous owner said they hadnt had any problems either.
The cr is alot smoother and refined then the old pd engine.
