Leon main beam on warning buzzer not working??
Motty
Hi there,
I have a problem with the warning buzzer for main beam on, in that the warning buzzer doesnt work when I open the door.
It's strange because it works if just the side lights are switched on.
Anyone got any idea?
Thanks.
Paul197
MK2 Cupra
Oct 27, 2010
162
Mildenhall, Suffolk
it doesnt chime if mains are on as you can use them for comming home lights they will stay on for 30 secs or whatever its set to then all turn off after that
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,304
7
Desborough
Sp if you leave your main beams on and lock the car they will automatically turn off after a while? I never knew this, will try it now tonight hahahahaha.
tonto
1,265
plymouth
mine turn off after about 1.5 minute.
the ammount of people that yell " you left your lights on " and i just have to explain that they should watch some magic.
and then they turn off. i win!
Redemption
1,771
Hampshire
I have to flash my main beam to activate them on mine (once the Coming Home/Leaving Home option has been enabled in the MFD). :)
tonto
1,265
plymouth
i dont have vagcom, or the larger mfd... so i guess it was like it from standard.
but i do have a bosch KTS diagnostic computer which works well, im sure i could use that - im happy to try and if anyone locally wants it done ill do it B-)
jc_boc
Jul 18, 2008
9,304
7
Desborough
Tried it out today and it works!!!! No warning buzzer but the headlight turns off after roughly a minute. I think it's a cool feature! LOL.
cupra123
65
is there any setting for if you unlock the car the headlights come on? wouldnt mind that when i cant find it in a car park :L
product
94
This does exist (called "Leaving Home" cleverly!), but you only have it in combination with the auto headlights.
It needs the sensor to know if its dark enough to bother, but if it is then yes, the lights come on when you unlock the car, and will time out again after a period you set with the MFD.
volts
89
Looks that way as the sensor decides whether to switch them on or not dependant on light levels.
