The video is pretty much spot on, You do have to remove the A pillar trim ( held on with spring clips and does take some force to remove ) This enables you to be able to remove the 3 little bolts that hold the quarterlight window in place , then you have access to the 2 bolts on the top of the wing. Once I had loosened all bolts I found there was enough room to be able to remove the black plastic spacer thingy that the wing and bumper both clip into ( 2 screws holding it on ) Which meant I did not have to remove the bumper.
Thanks for the replies, appreciated, wings are pretty knackered have patched them up but will replace, soon. So by the sound of it may get away without taking off front bumper. should have been done under warranty but poor help from Dealer.
