Plumbed the water meth wires through the car , can’t see any now , also mounted the controller unit under the double din , just need to feed the wires through the fire wall to he battery in next couple of days
This is going to be evilllPlumbed the water meth wires through the car , can’t see any now , also mounted the controller unit under the double din , just need to feed the wires through the fire wall to he battery in next couple of days
Just refitted the sump and put a new pick
Up in, was a few lumps in it but not to much, the
Oil pick was clogged , also bolted the water meth pump and tank into the boot of the car when the gasket sealant was drying
We have the same mattsWell I thought I had nearly put the water meth in but had so many more wires to do , wired it to the ignition so it arms it’s self when I turn the key , also fed the wire, boost line and squirt line through the fire wall, I ordered revo throttle pipe and had a email saying it’s out of stock , so I’ve had to buy a cts one for £210 . Here’s a video of the nozzle squirting
View My Video
Is them gains just with the pipe? Or with using the meth. Ive always looked at the throttle pipe and wondered why they stuck it in pancake styleWell just got the car theottle pipe in and water meth in and all I can say is wow it feels like the cars been remapped again, it is ridiculous , the power is just beserk! In the same league as my friends 510 bhp C63,
The throttle pipe was a nightmare to get in as it was so close to the fans , but it’s in and I’m
More then happy !! Car spools up much sooner then normal and the throttle pipe has made my dump valve so. Much louder , sounds the dogs bollocks
Im booked back in with rtech for a map tweak on my stage 2 as previously it only made 323bhp and ive since changed thinks il be happy with 340+ for nowThere’s some on the golfgti forum , 10-12 whp when they throttle pipe and turbo pipe on the other side , I think it is more to do with the smoothness of the air , more direct flow , I could be wrong though!
Your a madman...im not even at 2+ yet lolI’m posistive I read it gives gains as someone had a before and after dyno on a mk5 golf gti with both the pipes done , mine has definetely improved but don’t know how much is because of throttled pipe or water meth,
Lee you should get water/meth , I bet it will add atleast 20 bhp / 20 ft lbs
