After reading loads about fuel system cleaner Liqui Moly Diesel Purge on an American Tdi forum, I thought I'd give it a go on my Ibiza FR (ASZ PD130). Prior to posting this thread I had a search for the product on SeatCupra.Net but there's no mention, hence this post.
I bought some of the diesel purge on ebay and made the feed pipe rig as per this Youtube video. Having built the pipework I tried the product out yesterday. With a 500ml bottle it takes about 15-20mins of running the engine while stationary to complete the treatment. I got my friendly helper to rev the engine a bit throughout the process while I made sure everything was okay under the bonnet.
Anyway to cut a long story short, Does it Work? The answer for me with an FR Tdi with 68k is a confident yes. Following carrying out the purge the engine's definitely smoother on a cold start and the engine overall feels more responsive and smooth. Apparently post treatment the product reduces soot and smoke although I didn't have a problem with that in the first place tbh.
I have used Millers diesel additive and Forte diesel treatments for several years and the Liqui Moly diesel purge initially appears to have produced a superior result. I'll still continue to use the Millers fuel additive but think I will continue to carry out a diesel purge every 10k or so. I can't honestly say I'll continue with the Forte though.
I'd like to say that I am a natural cynic when it comes to 'snake oil' products but in honesty I think this one seems to work. I'll be doing my partner's Polo diesel at some point soon!
Here's some pics of the pipework I created as per the Youtube video - it's definitely better than just poking a couple of tubes into a clear bottle as others seem happy with.
Please note I am using fuel line between the T connector and the fuel filter as it gets hot with the engine running. Clear plastic aquarium tube might not be able to take the heat so why risk it. The clear tubing up to the reservoir bottle doesn't seem to get hot at all (it's clear so you can see the liqui moly being used up and enables you importantly to stop the process before running dry. The pipelines are 8mm bore or in oldies speak 5/16ths.
The completed rig
Close up of the Fuel Filter/ T Connector/ connecting pipe
Hole out of Cordial Bottle to enable filling plus string to attach to rubber bonnet stop to hold it during the purge
Fuel Filter Return (Doesn't have to be so long)
Well Done! you've got this far without nodding off
The whole rig only cost about a tenner from different ebay suppliers(of which there are millions) and from now on I won't be using Forte diesel treatment. Forte has a good reputation but the liqui moly diesel purge is nearly half the price of Forte and in my experience works a lot better. Now I have the pipework sorted I'm set for numerous diesel purges.
Plenty on other forums about it so don't just take my word for it. The Youtube video is excellent so should answer any q's. Failing that PM me or you're more than welcome to post in this thread
P.S. If this whole thing seems like a faff - it isn't and the results are worth it. In fact I'm looking forward to doing my next one
The completed rig
