Hi just fitted a liquid gauge was avin a play how gd is the bhp reading on it to wht u get on rolling road I only geting 267hp on mine on stage two but on rollers I get 290+ on and so was exspectin abit lower but not tht much
the liquid gauge works by reading the grams per second of air running through your maf and then calculates a bhp reading off that i believe. So its sort of accurate but its not going to give you perfect readings
Remember that temperature affects power output too mate. On a hotter day you will lose power compared to a cold one with denser air/ better intercooling.
The g/s calculation is only really any good on a non-remapped car. Remaps often use other things like advanced ignition timing to gain more power, the g/s calculation can't take that into account.
I have this. Problem as well I believe its because your maf readings max out you need a different maf to register higher readings than 270 bhp. I have been on 3 different dynos and all read very similar 315 313 318.
Pluged gauge in straight after and like It says only acheived 270 bhp
