List of fault codes ...
Gravesie-363
LCR 225
Aug 4, 2009
353
Darlington
Where do I start ...
2005 Leon Cupra R 225 ...
3inch downpipe decat non res cobra
Forge TIP
Forge recirc
N249 bypass
Stage 1 map (i believe)
Drilled air box standard panel filter
These are the codes i cleared the other day (was severely under powered)
P0420 - cat converter system bank 1 inadequate effect
I pressume cos decat
P1297 - connection from turbocharger to throttle valve
Pressure drop .... (Found intercooler to charge pipe almost off)
P1602 - power supply too low
P1287 - turbocharger recirculating air solenoid valve open circuit ...
With the bypass I done, I never read anything about a resistor at the time, and it has been fine for the past 2 and a half years so I don't think it's related to that
Help?!
