Hi,
My Arosa heating panel lights are no longer working and I've tried to see how I can replace them but I've not had much luck.
Does anyone know how to replace them?
Steven
On my daughters 52 Arosa the bulb is under the centre knob on the heater panel, it should just pull out and you should be able to see the tiny bulb in the middle. You will need a pair of needle nose pliers to gently pull the bulb out without breaking the glass.
A light pipe arrangement carries the light to the rest of the heater panel from that one bulb.
Thanks for the post, yes I unscrewed both the panel and lower tray, fiddled to pull it out bit and the white case at the rear of the centre knob pops off to reveal a very tiny bulb!
