Silver_172
Hi All ,
First post , Im trying to help a friend of mine out i scanned his car the other night with VCDS and ive been doing some research on some of the fault codes.
Im no VAG Master, i just have a Mk4 golf myself had a few issues worked it out using vag com and offered to do the same to help a mate out.
So ive had a look around heres the faults.
Suggestions/ Findings In Red
4 Faults Found:
00893 - Switch for Trunk Handle (E234) Suggestion :- Change the boot handle.
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 240
Mileage: 122111 km
Time Indication: 0
Date: 2010.05.18
Time: 16:48:32
Freeze Frame:
Term 15 Off
Voltage: 12.85 V
OFF
OFF
OFF
OFF
OFF
01038 - Central Locking Thermal Protection Suggestions Please ....
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 5
Reset counter: 243
Mileage: 121513 km
Time Indication: 0
Date: 2010.05.06
Time: 15:41:08
Freeze Frame:
Term 15 Off
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
01135 - Interior Monitoring Sensors Finding :- This is on all cars nothign you can do about it ? is this true ?
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 85
Reset counter: 10
Mileage: 109244 km
Time Indication: 0
Date: 2015.06.05
Time: 08:10:26
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3) Suggestion :- New Bulb
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 25
Reset counter: 250
Mileage: 119424 km
Time Indication: 0
Date: 2010.04.06
Time: 10:57:58
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
OFF
OFF
ON
Any help Greatly Appreciated , he's having an issue with the Drivers door and Rear Passenger Door i was thinking about just swapping the Door Lock modules out on both sides. but with the interior sensor issue also got me thinking the problem is much bigger than that.
