??Faced with a massive bill i think the op is quite entitled to ask for advice on a specialist forum ?
Hi,
Have recently had coolant leak and trusted local garage told me It’s blown head gasket as they found fumes in coolant.
Looks like coolant being pushed out by pressure created by fumes in cooling system.
Anyone had this issue?
Is there any chance that this is something else than gasket?
Its 63 plate seat Leon Fr 2.0 tdi 184Can you give us more vehicle details?
Where is the coolant leaking from?
It looks like is being pushed up the system and comes out from top outlet under cap.
What about fumes in coolant? Does it happen when matrix is clogged? Have had that blue liquid turning green when testing...That is a classic sign of a blocked heater matrix. Have you had that replaced or had issues with it?
Obviously motorway driving is drinking a lot, day to day driving is not bad but still.I know of some people who have had positive tests due to presence of gases, possibly due to the EGR cooler or similar influencing the coolant. I can't say for sure but I know it isn't 100% cast iron proof of HG failure.
If you have milky oil or steam coming out of the exhaust then HG is likely.
The heater matrix over pressure and venting via the header tank cap only happens during/directly after a DPF regen when it's super hot and the blocked matrix stops it cooling properly. Any idea whether your coolant loss is all of the time or once in a while?
You can kinda do some tests/fault finding to see if the matrix is a potential issue. It's a known issue with the TDI's.
Just trying to save you going down the HG route before you have to shell out £££'s.
Still considering this option...Get the car traded in and cut your losses i would say
is the car getting up to temp as quick as normal?Well, have had head gasket replaced...consumption is much worse now!! Is it normal after head gasket replacement?? What cause this?
Hi,is the car getting up to temp as quick as normal?
