Loss of Acceleration
Birky12
Hi
I have a Seat Leon FR TDi 2010 and today when I was driving home today and when i put my foot down to accelerate up a hill. There was no power from my engine. It was completely flat. There was no Poping sound and there are no obvious splits in the intercooler hoses and the turbo sounds fine. There is also no Engine management light on the dash and when i used Vag-com to check for fault codes there were none found. Any Ideas? the quickest i can get booked into the dealership is next wednesday and its 43 miles away!!
Thanks in advance
greyfloppyhat
Senior Member
Jun 14, 2011
673
Dublin/Belfast
Do all the lights on the dash definatly work? The fact vag com didn't log anything is odd, are you able to replicate the problem?
If the boost pipe popped off you would know, you'd be pluming black smoke out. MAF sensor may not be working 100%, if you can replicate the problem try disconnecting it and then go out and try replicate it again
Birky12
Removed the MAF its clean and there is no change. Not even smoke. I noticed that with the car parked in neutral the revs wont go past 2500. But when moving if i dip the clutch it will rev right up to 4000. I can't think of anything else it can be :(
bobak
Opinionated non-mechanic
May 15, 2008
203
You're in limp mode.
You need to plug the car into a vag.com or similar and get the error code. I suspect it may be "Turbo Overboosting". Then clear the fault. If it is this fault, it could be a number of things.
Most likely a faulty or erratic sensor. The fault might not even come back.
Alternatively it could be a dirty turbo, needing a strip down and clean, or a faulty turbo or frankly a few other things - im not a mechanic so i'm not certain. If there's no excess smoke out of the exhausts then its probably not the turbo. Fingers crossed.
Either way, get it to a vag.com or a computer that can read the fault. Call SEAT and see if they can plug it in for free. Be warned, they'll be quick to tell you your turbo needs a rebuild or something, so if they do i'd get a second opinion.
My local SEAT dealership are rude and expensive and wanted £95 to plug the computer in (5 minute job!) - Bristol Blade SEAT so I called up SEAT Congressbury who plugged my old car in for free and were really nice. So if your local wants to charge, call around or see if someone on here has VCDS
Hope that helps
Birky12
Thanks for the reply. I have vagcom and it hasnt found any fault codes. Its under waranty but just a pain in the arse not having a car for a week
bobak
May 15, 2008
203
hmm... thats weird. Well, obvious cr4p answer but... take it to a specialist or dealer, see what they reckon.
All the best mate
Birky12
Ill try again tomorrow. It might throw a fault code up! Thanks again for your reply much appriciated
Birky12
Wednesday,16,May,2012,11:18:49:49104
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZAR019776
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 GN HW: 03L 906 022 GP
Component: R4 2,0L EDC G000SG 5764
Revision: 13H01--- Serial number:
Coding: 0050072
Shop #: WSC 06402 785 00200
VCID: 77D3313B06D6651
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AM HW: 1K0 907 379 AM
Component: ESP MK60EC1 H45 0108
Revision: 00H45001
Coding: 163B601289230003681206EB911F00823408
Shop #: WSC 04941 000 00000
VCID: 7DDF2313E4EA4F1
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 31306 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 397
Count: 51033
Count: 0
Count: 65017
Count: 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 M HW: 5P0 907 044 M
Component: Climatronic H14 0401
Revision: 00001001
Coding: 0000000000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_SE35.rod
VCID: 3A55E80FBD44B89
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 HW: 5K0 937 086
Component: BCM PQ35 M 008 0019
Revision: BC008001
Coding: 46180A3C9025B0C04688008095008104050100A8425D81605C8040000000
VCID: F1C78F2328B2BB1
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 18080 22 0601
Coding: 00DB90
Subsystem 2 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Coding: 000000
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Coding: 000000
4 Faults Found:
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 170
Mileage: 31234 km
Time Indication: 0
Date: 2026.14.30
Time: 07:12:09
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 67
Reset counter: 174
Mileage: 26499 km
Time Indication: 0
Date: 2023.14.29
Time: 15:29:57
Freeze Frame:
Term 15 Off
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
02394 - Parking Light Left Front (M1)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 32
Reset counter: 153
Mileage: 28081 km
Time Indication: 0
Date: 2024.14.26
Time: 10:24:42
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Right Front (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 171
Mileage: 28063 km
Time Indication: 0
Date: 2024.14.25
Time: 17:05:05
Freeze Frame:
Term 15 Off
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__A0E VW10 HI 1916
Revision: 20013000 Serial number: 003E2PDPCRPH
Coding: 0012357
VCID: 44A996F70780FE9
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 855 0111
Coding: 0000732
VCID: 78D132070BC86A9
Subsystem 1 - Part No: 1P0 959 538 B
Component: E221__MFL-TAP 01ÿ 0100
Coding: 00000226
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 954 HW: 1P0 920 954
Component: KOMBI H17 0109
Serial number: 00000000000000
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: EEFD945F318CA49
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K0982506A7
Coding: E9807F06000612000203
VCID: 66ED6C7F517CEC9
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H17 0109
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE35.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667541806
Coding: 020000
VCID: 266D2C7F51FC2C9
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000533098601
Coding: 0004784
VCID: 40A19AE71398E29
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 142 2901
Revision: 00H15000
VCID: 2F43C95BBE066D1
2 Faults Found:
16353 - Control Module - Internal Malfunction
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Battery Volts: 0.0 V
PD
Temperature: -70.0°C
Error Code: 0
Torque: 0.0 Nm
Torque: 0.000 Nm
RPM: 0 /min
16355 - Control Module - Watchdog Timer
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 6
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 0.00 V
PD
Count: 0
Count: 0
Count: 0
Count: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000505498518
Coding: 0004784
VCID: 41A79FE31892EB1
Birky12
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1P0 035 153 HW: 1P0 035 153
Component: Radio H03 0008
Revision: R0000000 Serial number: SEZAZ1I7820593
Coding: 0102040004
VCID: E2E5F06FFD54109
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000004169110
Coding: 0000144
VCID: 74C9063717A00E9
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000004185637
Coding: 0000144
VCID: 75CF3B331CDA171
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005084841
Coding: 0010555
VCID: 3851F2074B48AA9
End ---------------------------------------------------------------------
Thursday,17,May,2012,07:25:43:49104
Chassis Type: 1K0
Coding: 0050072
Revision: 00H45001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 31306 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 397
Count: 51033
Count: 0
Count: 65017
Count: 0
Revision: 00001001
Coding: 0000000000
Revision: BC008001
Coding: 00DB90
Coding: 000000
Coding: 000000
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 170
Mileage: 31234 km
Time Indication: 0
Date: 2026.14.30
Time: 07:12:09
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 68
Reset counter: 175
Mileage: 26499 km
Time Indication: 0
Date: 2023.14.29
Time: 15:29:57
Freeze Frame:
Term 15 Off
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 32
Reset counter: 153
Mileage: 28081 km
Time Indication: 0
Date: 2024.14.26
Time: 10:24:42
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 171
Mileage: 28063 km
Time Indication: 0
Date: 2024.14.25
Time: 17:05:05
Freeze Frame:
Term 15 Off
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Coding: 0012357
Coding: 0000732
Coding: 00000226
Shop #: WSC 00000
Coding: 410A00
Serial number:
Coding: 020000
Coding: 0004784
Revision: 00H15000
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 0 km
Time Indication: 0
Freeze Frame:
PD
Error Code: 0
Torque: 0.0 Nm
Torque: 0.000 Nm
RPM: 0 /min
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 0.00 V
PD
Count: 0
Count: 0
Count: 0
Count: 0
Coding: 0004784
Coding: 0102040004
Coding: 0000144
Coding: 0000144
Coding: 0010555
silver surfer
470
out there over the edge vw tech
Try this remove engine cover and at back of engine on top of turbo you will see a round unit with an electrical connector on top and on the right side low down a vacume pipe remove pipe fit a nother bit of pipe and suck on it if you get resistance vac unit ok if you suck for ever its shot .this controls turbo so no power if not working and the unit can be replaced on its own
greyfloppyhat
Senior Member
Jun 14, 2011
673
Dublin/Belfast
I agree, VNT vanes could be ceased up
Birky12
Well whatever it is im gonna have to wait til monday when i get it to the dealers. Its only done 20000 miles :( and i give it the beans on a regular basis. Thank you for your replies!
bobak
May 15, 2008
203
Right well I think I've got to the bottom of what happened on mine (fingers crossed). Went into limp
bobak
May 15, 2008
203
Hopefully got to the bottom of mine (fingers crossed). After a week of the guy resetting the fault I noticed a bit of juddering, some flat spots and a hissing when I accelerated. Took it to the garage today and the clip holding the hose to the intercooler had broken. They replaced it and seems ok now.
Charged me £60 though, £30 diagnostics and £30 labour.
Fusster
148
This is the correct solution,it wont be the vanes,the vacuum capsule will not be holding vacuum,it will induce a fault but it takes a while .as silver surfer says there is a repair kit.
Birky12
Well it decided to come out of limp mode when i took it to the dealers! been there for a couple of days and they say they cant find a fault and have contacted SEAT UK for help and have yet to hear back off them.
They also told me that their diagnostic equipment could not communicate properley with some modules in the car. If they are stuck what hope have I got if they can't fix it.
SHADY-NINJA
993
London
www.airconmedic.co.uk
when the DPF heats up and coupled with a few missed regen opportunities the car will lose power untill the engine has cooled down.
what type of driving do you do??
motorway or town/school/supermarket sweep trips?
DPF faults dont usually bring up engine management lights.
the dealers must have mentioned DPF issues to you.
if not, mention it to them.
when the engine has cooled down you can do a forced regen
or just let the dealers do it under warrantee.
