i recently noticed, while overtaking, a sudden drop in power. almost as if the car had gone into limp home mode. so i ran vagcom and this is the result:
Control Module Part Number: 038 906 012 FK
Component and/or Version: 1,9l R4 EDC G500SG 3357
Software Coding: 00002
Work Shop Code: WSC 06403
Additional Info:
1 Fault Found:
17563 - Manifold Pressure Sensor (G71): Short to B+
P1155 - 35-10 - - - Intermittent
Control Module Part Number: 1M0 920 922 D
Component and/or Version: KOMBI+WEGFAHRSP VDO V03
Software Coding: 05422
Work Shop Code: WSC 00476
Additional Info:
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
any ideas? are these just wiring faults or have i got a couple of duff sensors, and if so where's the best place to get replacements?
Additional Info:
1 Fault Found:
Additional Info:
1 Fault Found:
