Oct 3, 2025
I recently replaced the head gasket on my BMN engine,
but have missed the tightening of the rocker arm adjustment screws,which resulted in a lot of smoke and over reving,when removing rocker cover, injector no 1 in between the sping, the two plungers have completely blown out also all others had came off,have found all bits, Apart from 1 adjuster screw, where could it have gone from inside the rocker head as cannot see how there is an opening anywhere for it to have gone,plz help,where should I look???
Could be anywhere, you didn't put the engine back together knowing you were missing an adjustment screw did you?
