loud banging noise from engine
torquesport
Lets Torque Diesel
Jan 19, 2008
137
Stone, Staffordshire
hi im new to seatcupra.net and i dnt know if this is the right place to post!
i brought a 1998 seat ibiza gti cupra 2 days ago i drove it 90 miles home and it was fine took it out again and i started to hear a loud banging noise coming from the engine and since its got louder so it isnt being used at the mo.
so yesterday i fired up the car and there was the banging so had a look under the engine and when i put my hand under the started motor and lifted it up the noise stopped so i took off the started motor and had a good look and it seemed fine also i tested the motor and it works fine.
so i put it all back and the noise is still there, when u turn the ignition it started but not every time you start it but i does start when you are driving the car the faster you go the faster and louder the sound gets, the car goes through the gears fine and its had a refurbed gear box fitted about 5 months ago.
but say i started it up and the noise starts and i push the clutch in it stop let it back out and it started again, at first i thought maybe the drive shaft has come loose but it is fine.
any ideas would be very gratefull
cheers ash:(
torquesport
Lets Torque Diesel
Jan 19, 2008
137
no its worse than that its more like a clanging noise coming from the passanger side of the engine but i did find come thing the other day its was a piece of metal which was flapping about it was like a shield which shouldof been bolted on but something has been chomping away at it it was near where the drive shaft meets the gearbox:confused:
