MAF and airbox mods
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
okay gonna smooth the airbox on the car as soon as i can source a dremel and am interested in cutting the mesh from the MAF, am a little unsure about this and have read conflicting stories ,
so someone tell me the science behind this how it works etc , and the good and the bad bits,
thanks as always ,,
stephen
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
there's no point in removing the mesh...
it straightens the air so that the MAF can ready accurately.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
thats what i thought all along too mark , but ive read posts on ukmkivs and such that say it does very little in that respect and that removing the mesh allows more air , but says it affects fueling etc ,
i dunno:confused:
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
surely you can remove the sides of the mesh as its not measuring the entire housings worth of air, just the air in the proximity of the sensor?
Im not convinced its a noticeable worthwhile mod though.
karl.w
methanol junkie
Oct 26, 2005
606
i wouldn't bother removing the mesh from the maf. cant see it making much difference at all. just smooth the airbox and stick a large cold air feed in and you should get good results
Tabintab
Newbie
Sep 15, 2006
80
Peterborough
Ok, im an Aeronautical Engineer by trade, so I have done all that aero dynamics stuff.
If u put just about anything into an air flow it will cause turbulence. Now if u look at the cross section of a wire its circular in shape, i.e. its going to cause turbulence, and looking at that mesh, well there is a lot of wire in there. I can’t see any way you will be straitening the airflow in that way.
The mesh will be restricting the air flow and causeing turbulence.
I have seen devices fitted in intakes to shape airflow, but this is not it :)
Tab
sssstew
Editing your spelling
Tab
so why would bosch engineers fit it then?
Tabintab
Newbie
Sep 15, 2006
80
Peterborough
It has to be to stop particulate matter, which makes me think, but the car already has an air filter!
Maybe its to disturb the air, so the MAF gets a reading from a larger sample of the air? But i have read there are some cars with 2 filters, 1 in front & 1 after the MAF.
Maybe its just a safty device to stop larger objects being ingested, tbh, I just dont know.
Tab
cheshire cat
1,813
cheshire
Tab
the inner tube is there for the particles that go thro' the air filter:blink:
muddyboots
Still hanging around
Oct 16, 2002
5,739
I guess there is always a risk that a paper air filter could disintegrate, perhaps if it got damp - so the mesh just could be a last measure of protection to stop anything getting sucked into the turbo and causing damage :shrug:
F2 Ed
now has VAG com
Nov 5, 2006
919
www.superlite-wheels.com
A little turbulance in the air is needed. I think the turbulance is needed to help mix fuel you see.
How do you smooth the airbox? You mean open it up and smooth the inside? Will the filter element still fit ok?
Interesting stuff
Tabintab
Newbie
Sep 15, 2006
80
Peterborough
yip green panel filter still fits , i used a dremel tool to cut the ridges out and sand paper to finish
I have an Altea 2.0 sport TDI & just out of curiosity took a look at the inside of my airbox to see how much material could be removed if i ever considered smoothing the inside. Well I'll never need to do it, cause its mostly smooth in there alrdy :) thanks Seat.
Tab
Tabintab
Newbie
Sep 15, 2006
80
Peterborough
Interesting stuff
I understand why you think turbulance is needed, but tbh I think it has a negative affect. Think of why people port & polish cylinder heads! Smooth baby, smooth :)))
Tab
