Hi Guys
After cleaning out the turbo, the inlet manifold and then giving the EGR valve a new home in the shed I found I'd got a flat spot in the rev range at about 2700 rpm.
I scanned but had no fault code, so after a bit of research I replaced all the vacuum hose with silicone and that reduced the flatness
blink
of the flat spot considerably.
Anyhow after a scan with the new silicone hose installation I've now got a code,
17552 P1144 Mass or Volume Air Flow Circ Open/Short to Ground
Does that code mean I need to replace the MAF sensor or is there a fault in the socket/ power supply?
Many thanks,
Lee
Many thanks,
Lee
