Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Loved your RR. The Fr is top notch. Good effort!!!
I absolutely love your custom center grill. Where did you get that actual badge from?
Lovely car mate just spent best part of an hour reading full threadkeep up the good work
Absolutely loving this car!
I take it you are still running on APs after a few years and with the miles you do I'm impressed! How does the ride compare to standard?
APs were definitly better than standard when I first fitted them, wound all the way down but with all the adjusters etc in. (no helpers on these).
It's not great now, I'd guess I'd done about 80k on them so they are probably getting tired and they having taken out everything aside from the spring them are running lower than they were designed to be. Part of the problem running this low is if I'm going a moderate speed (as low as 20-30mph) with much crown to it it will scrape the subframe![]()
You had issues with mot and no helper springs in?
APs don't have helpers, the spring is non linear instead
At the rear it needs the rubber top bit to the spring in just to make sure they don't wiggle when jacked up . They usually fall instead the spring a week or two after refitting as I cut them down from 10mm to 5mm thick
