Melting Rear Lights?
Jun 7, 2006
2,983
Norfolk, Norwich
So went out in the car today after a long trip yesterday (4 hours driving) and the rear passenger side light looks like its got sooo hot its started to melt.
can see where the vaccum has sucked it in and its touching the light now
any one else see this before
cheers
lee
Jun 7, 2006
2,983
Norfolk, Norwich
no idea never changed them had the car 3 years and would probably say standard original maybe??
only thing i done to them and that was years ago was wrap them in tint
baffled
think its worth getting the auto electrician out to voltage test. i checked all the lights and everything is working
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
If the voltage was too high the bulb would probably burn out. You sure nobody has kicked it or hit it whilst parking?
Surely it would crack though if someone had hit it?
Definitely looks like its gotten really hot for some reason, worth getting an electrical test done to make sure everything is ok
Jun 7, 2006
2,983
Norfolk, Norwich
are there lower wattage bulbs you n put it?? LED etc that run cooler for future?
ill get Dave to send me a new rear and order some more tinting film but i will need to get the electrics checked
only things that have changed recently.
Service
APR Remaped again with Switchable mapping
after a closer check i am 99% sure its not flames or heat from exhaust as i have the diffuser that covers a lot of the tip and the light next to it is closer and fine so its definitely happened from the light internals
what i am wondering thought that is the corner that i recently had a little argument with the wall (all repaired and no big issue but i wonder if that had pushed the light in a little when it was hot the and cooling has caused a vacum effect??? im plucking at straws here. lol
defo want to replace all teh rear bulbs for Cooler LED if some one knows which to get ill get them ordered and hope it doesnt happen again
lee
Jun 7, 2006
2,983
Norfolk, Norwich
i love that to be true but if it was shooting flames id be worried that my sports cat was screwed lol
i need to find LED bulbs. ebay have some that have the resistors for rear bulbs but im not sure
lee
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
only time I've seen this before was when an engineer at last place left his car in reverse (engine off) to illuminate a work area and it melted lens as it was on for ages.
Hawkins
31
Could you have parked near to something hot, a hot air vent from some kind of machinery maybe?
