Nick_J
376
Milton Keynes
www.facebook.com
So guys, who on here uses Millers fuel additive? and seens as I have now started venting , and use Millers, I would lke to know who does both, because some people say the warranty will be invalid if they find the fuel pump defects while using MIllers additives.
So here goes, who uses Millers and has had problems with the fuel pump, becuase I would like to know what the general ratio is.
Its all well and good saying that if SEAT pick up on the fact that if the Pump defects while using an additive then your not covered, but who has actually been in this situation against the amount of people that use an additive?
If that makes sense!
a friend tunes evo's, and he tell's me that as long as you mix it to the correct ratio you'll be fine, but i suppose thats common sense anyway. Throwing a bottle into a tank doesnt incresase the RON anymore than the correct amount does
As long as you use Millers sport 4 which is designed for PD engines ( providing your putting it in a PD engine ) i cannot see how Seat could prove it was from using the additive and if they did try it on i would get a letter saying so and get in contact with Millers Oils and tell them to sort the situation out or you will sue them to pay for your car to get fixed.
