minimum pad & disk thickness on LCR
andyj
There's no F in Quality..
Guys,
Does anyone know the minimum thickness for the front brake discs and pads on the LCR ?!?
Was having a look yesterday when cleaning the car, and it looks like mine are getting low.
Also looks like Pete fitted Ibiza pads, as there's no wear indicator on there at the mo, and there's a 'bodge' to fool the ECU ;)
Reckon I've got about 3mm pad wear left.... not too sure on the discs.
Andy
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Quite a few of the popular aftermarket pads don't come with wear sensors so I wouldn't worry about that too much :)
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Stolen from another thread...........
Ruddmeister
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Yeah, my driver's side have always worn faster (about 4-5 sets now, always OE kit).
The pads are very thin as new, from memory only 6mm. My verniers (my micrometer doesn't either, but I can't remember why) don't fit over the lip on the disk, so I use either the lip itself to judge or something like two coins (measure the disk and the coins together, then the coins on their own and take one from the other...).
Sam20v
949
Dubai UAE
So long as you dont get metal rubbing on the discs scratching them to :censored: you will be ok......hahaha gotta get your money's worth!
with regard to the disk...you may find the thinner they get the more likely they are to warp and you will have a nasty vibration on braking!
this is more likely to happen when stopping at a junction for a while after allowing brakes to heat up...when discs are thin they cool quickly and the hot pads squeezing on to one part of the disc (slight expansion i guess) will contribute to warping....i read that somewhere...:redface:
RobM
Sep 27, 2006
4,982
Southampton
That's true regardless of the state of your discs and pads... if you heat them up (say, after slowing coming off a motorway) and sit in traffic with your foot on the brake, you risk warping the discs pretty quick.
