AP2000
Toledo TDi 130
Apr 12, 2007
90
Midlands
I'm after some front and rear pads and discs soon. I don't hammer the brakes.
Would you recommend Pagid or Mintex standard pads, and with EDC or Mintex discs?
Someone on Ebay selling rear pads and disc Mintex for £56 and fronts for £90. So quite decent £146 for all round pads and discs.
312mm discs at the front I believe and 256mm at the back.
Just been on Euro car part, Pagid all round discs and pad come to just less than £170. So which would you rate better, Mintex or Pagid all round?
Thanks.
Just measured the front and they seem to be 288mm. After some searching it appears that I need a conversion kit for the 312mm so I won't be doing that.
Are the rears 232mm or 239mm as I cant see 239mm listed anywhere.
my apologies mate, yeah they are 232mm id just been lookin at something completely different which was 239mm lol
No problem, it just confused which doesn't take much?
Don't suppose you have a link for the correct discs and pads on Ebay or Euro parts so I don't order the wrong ones.
Thanks mate, great work!
I think I found similar ones one there but choose the ones with wear indicators. £114 all round discs and pads seems decent. Just need to decide if these Pagid or Mintex are the ones to buy.
you will need the ones with wear indicators as the sensor goes in the passenger side front, to be honest i doubt you will notice much difference between the two makes with just standard brakes, maybe mintex slightly better but its entirely up to you
