Hi guys,
Frequent lurker, infrequent poster here.
I have a 2007 Leon Cupra which is currently throwing up a code for misfire on cylinder 4. I have done some fault finding and would very much appreciate a few pointers as to what I should do next.
I have swapped coil packs and spark plugs with cylinder 1 and the fault remains on cylinder 4. Can someone let me know which way the cylinders are numbered (i.e cylinder 1 on nearside or offside of vehicle).
I understand that it may be down to carbon build up on the inlet valves or possibly an injector.
Is there any way to diagnose a fault on the injector without pulling it? I only have Carista to assist me with ecu faults (plus a cheap ebay scan tool).
If the injector is at fault, can I get away with changing just one or is it a full change out? Normally this would be ok, but it's going for a respray next week so I've dumped enough cash into it already, especially after getting a quote for £600 for a walnut media blast!!
I know that there is a tool for injector removal. Is this 100% required or can it be done without.
Does anyone know the details of what's involved when replacing the injector? (aside from disassembly of the manifold etc) Clamped in, push fit, push and turn etc.
I am planning to tackling this on my driveway (I'm a marine engineer, so these engines are a lot smaller and more fiddly than I'm used to, but plenty of research and prep and all should go well). I spotted a fantastic how-to from a user on here (Lee_M), so that will be my main guide.
I also plan on cleaning the inlet valves while the manifold is off. I will fabricate some thin copper scrapers and hooks to help me with this. Does anybody have any recommendations as to which carbon remover chemicals to use? We have some carbon remover for the turbochargers on my rig but I'm sure there will be better stuff available here.
Sorry for all the questions and the long story, hope someone can point me in the right direction.
Cheers,
Gordie
Cheers,
Gordie
). It's very much appreciated.
