Mk1 leon central locking.
Jan 9, 2020
Hi everyone,
I'm new here, I've searched all the threads for my leon locking problem and couldn't find anything.
I'm having trouble with my central locking. It stopped working just out of the blue. Changed battery no luck. Got key tested, signal is fine on the key.
If I put the key in the drivers door lock, it will open all the doors but will not lock any doors except the drivers door. Back drivers door does not lock via central locking (when it was working) or the lock button on the drivers door.
I've already got one lock (front passenger door) replaced as it was dead locked. Couldn't open it from inside or out
Anybody know what the problem is with my central locking as it's really starting to annoy me.
Central locking unit/module? Where is it located.
Also have wet carpets in the back of the car on the floor
mty12345
3,768
475
bristol
If you have access to VCDS then you can scan the central locking system for faults. Note however that its under 'central convenience' in VCDS rather than 'central locking'
