Mk1 Leon epc light on wont start
Lewisbigbear
7
my car was running after I pulled away at a junction after 50-100 yards it just shut down as if I killed the ignition. Then the epc light came on. I coasted it over then tried to restart. It seemed to just turn over but with no fire or spark just a wurring noise. I've replaced brake light switch sensor and tested clutch switch sensor still the same problem. Any help would be really appritiated :)
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Any codes?
Sent from my Nexus 6 using Tapatalk
Lewisbigbear
7
Any codes?
I haven't got an update maxi but when I just read codes it says no faults found but when I first done it when it happened it came up with poco1 I believe. But plugged it in today and says no faults found. Engine management light is on and it lets me turn it off but doesn't state that there's a fault! I've got a maxidial I believe it's called. Diagnostic comp
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Use vcds/vagcom mate
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
I haven't got a decent laptop or a cable to use that but very helpful to know thanks Andrew. I have the 1.6s 16v I had the 1.6s golf which I personally think is identical to this one.
Yes should be the same mate. Look on shpock or gumtree for people with vcds... normally charge£10-£20 for full scan and help..much better than dealer's
Lewisbigbear
7
Thanks mate. Yer last time I used a garage not a dealer it was£100 for diagnostic hence why I bought the little machine. Lol il be keeping my eyes out for vcds now and it's saying to clean a few things before a purchase so il give all the cheap options a go first gotta start somewhere lol
