ok, i dont post a lot on here, have never needed to by searching i have found nearly all of the small number of problems i have ever had but this one is really causing some issues.
i will try to keep this short ( 2001 mk1 leon 1.8t )....
10 days ago the electric window cable snapped in the drivers door, speaking to seat they wanted a huge amount of money for all for the parts required as it really did some damage. thankfully the window did not break when it slid all the way down.
i managed to get a complete internal metal card with motor and everything required off ebay for £50.
i removed all of the old window mechanism, the metal door card everything not required from the car. plugged the new motor into the loom and checked that all worked fine, moved the two metal clips to inline with the holes in the card so i could slide the window down and bolt in place.
once this was all done i put the door card back in, connncted everything up and had the wife sit inside the car, shut the door tried the locks and all seemed fine.
she opened the door from the inside, i removed the door card once again to tighten all bolts on the metal card, make sure all of the loom is not fouling on anything etc etc
i shut the door ( again wife in car ) with no internal door card just the metal one, locked the car. tried to unlock it and the remote central locking and using the key would only open the drivers door nothing else?
after spending most of the day messing around with this i had enough and decided to leave it and look again in the morning. i later had a call from my dad ( the car was at his place ) he said he tried to open the drivers door with remote and key in door with nothing happening.
you could here lock / mechanism movement in the drivers door but nothing happening. all of the other doors were still locked, in the end he went in through the boot, and manged to open the front passenger & rear drivers door from the inside.
the driver & rear passenger doors remain locked no matter what you try.
speaking to my local garage before i even think about calling seat, they believed there is a control module ( or something like that, that works on the central locking ) and if this was to have failed then a trip to seat it will be.
can anyone shed any light on this? before i go speneding lots of money...
