mk1 useful part numbers list
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
Marbella clutch cable
SE 028 110 699A
Ibiza mk1
Clutch Cable
SE 023 126 201A
Fuel Flap Spring
SE 021 586 250A
Indicator/Flasher unit
SE 022 959 000A
Micro Switches (i think were for doors but been a while)
SE 021 951 007A - Black
SE 021 951 007B - White
Speedo Sender / Transducer
SE 021 940 000A
finally gear stick mod as they used to break apart a lot
Gear Box End:
SE 021 129 110A - coupling x1
SE 022 129 114C - washers x4
SE 021 129 108A - Pin x2
NR 110 641 176 - Clip x2
Gear Stick End:
SE 022 129 109A - Bush x2
SE 021 129 108A - Pin x1
tip: place large o-ring (greased) under gear stick ball to cure sloppy gear stick
all i can find to hand at present
Joey
Vented
Nov 11, 2011
18
Carlisle
Just bought a MK1 Ibiza K reg. pics to follow. Very useful list of part numbers thanks. Unfortunately the fuel flap springs are no longer available, there are only 2 speedo transducers left in uk but @ £59 they kinda double the cost of the car, lol! Think I've found a donor car at my local scrap yard. He reckons he can supply, NSF door lock actuator, rear wiper motor and heater motor. The electric windows have packed in aswell so here's hoping. Any suggestions where to source parts greatly appreciated :)
UnIbizable
Bosch out of tank fuel pump
0580464070
This fits loads of cars of the same era including BMW, Citroen and Renault
