MK2 Cupra TFSI Induction and dump vale help
Crezzlin
42
Guys is it possible to fit the induction kit and a dump valve kit or can you only use one or the other? Probably a dumb question but I have only used K&N simple kits before on none turbo engines. Thanks :stars:
Brimfull
1,385
418
Wrexham
Forget the dump valve.
The ram air over seized air intake is all you need as this produces the hiss and whoosh sound that you get from a dump valve.
Sent from my SM-G960F using Tapatalk
Legojon
I only wanted a remap
5,284
2,714
As above. Dump valve will just leak boost and cause issues. There are loads of open cone induction kits on the market for the Cupra. I've got the Revo intake kit and love the noises it makes! Especially when your flat out and change gears!
Reactions: Brimfull
Crezzlin
42
Thanks Guys, my mate gave me his Recirculating Valve kit for a small price because he smashed his car :( but i already have the induction kit ready to fit :s Problems aside is it possble to fit both or is that not possible? even if its just to try.. Thanks
Brimfull
1,385
418
Wrexham
As stated the dump valve will more than likely cause more headaches than it's worth with boost leaking.
Reactions: Legojon
