The lock is working on the fob just not the boot release or unlock the light isn't coming on either when i press the buttons, I've had a little search does it mean new fob time?
And how to sync fob and car together.
It's simple enough to do. Just need a flat headed screwdriver. Flip out the key. There's a small gap where you stick the screwdriver and twist. The key should open up into two pieces. Slide the top half off. The bottom half has the battery, all you do is open this part with your finger nails. Then the reverse for putting it back together.
no, the lock/unlock is is seperate from the immobiliser (immobiliser uses a glass chip in the blade part of the key that is sensed when the ignition turns on)
My Lock button works fine but my Unlock and Boot Release doesn't,
and as said by a few people it'll cost a bit to get fixed, we're talking £180+ when all i can do is buy a couple of quid replacement?
