Gibbo.
97
Ilkeston, Derby.
The lock is working on the fob just not the boot release or unlock the light isn't coming on either when i press the buttons, I've had a little search does it mean new fob time?
And how to sync fob and car together.
I'm going to try to take it apart tomorrow. Got the car in for an mot and service tomorrow. Wonder what they will charge to fix or just try my luck?
Got the car back today. The keyfob works now and again. Think it's probably the battery.
What do yous think?
Am I right do not need to Recode the keyfob if I replace the battery?
It's simple enough to do. Just need a flat headed screwdriver. Flip out the key. There's a small gap where you stick the screwdriver and twist. The key should open up into two pieces. Slide the top half off. The bottom half has the battery, all you do is open this part with your finger nails. Then the reverse for putting it back together.
Bumping this thread as i've just seen something online but not sure it'll work,
so any advice would be great,
sooo.. just seen this;
http://www.ebay.co.uk/itm/VW-Passat...cessories_Safety_Security&hash=item2a15e184d6
''A perfect replacement for broken buttons ''
My Lock button works fine but my Unlock and Boot Release doesn't,
and as said by a few people it'll cost a bit to get fixed, we're talking £180+ when all i can do is buy a couple of quid replacement?
