Hey Brady.
I have fitted Heko deflectors to my Leon 5 door.
I had to remove the metal clips after a few days as the noise they made when the window went up and down was ridiculous.. also as the clips push apart the window seal.. the wind noise was horrendous also.
The deflectors seem fine without the clips now.. except the driver side one..
The window channel is at the top is so thin, the deflector doesnt really have a place to sit.. and it keeps slipping down.
How did you fit yours so well and stop the window catching? Also do you have bad wind noise as well with the windows up?
Hi, where abouts have you placed your metal clips? For the front deflectors mine are in the small vertical section of channel towards the front of the window, roughly level with the wing mirror.
No noise from the clips, have you pushed yours all the way in? I used a small screwdriver to push mine as deep into the channel as possible (gently though!)
My rears are loose, supplied sticky tape was useless and sparse. The clip saved them from dropping out on the motorway though thankfully.
Fronts fit lovely, as for wind noise there is only a slight rushing noise from the shape of the deflector as to be expected, there's no excess noise caused by misshapen window channel seals.
Hope this helps.
Sent from my SM-G935F using Tapatalk
