ALEXZ360
Hi everyone, I have seen a few people modifying there forge induction kits using silicone hose, was just wondering if anyone had the diameters of piping I need to make this happen
I.e A 90 degree bend from the air intake connecting to the forge filter then a straight pipe connecting to the air intake scoop at the front of the car,
I would do this myself but I haven't received my kit yet,
Any help would be great,
Alex
I will be doing this on my itg. Im just going to get a 90deg silicone hose. You need to check the diameters of the pipe going to the filter you have atm. A couple of metal screw clips will be needed. Also theres a pipe from the block, part of the pcv system that goes to the intake. It vents any gasses out of the block back into the intake to get burnt. Not good for the enginge so I have left mine un connected. Maybe get a longer tube and zip tie the tube so it goes down through the engine bay
That's what the pipe is !! Been trying to figure if it was the crank case breather pipe. When you left it in attached did it not flag up warning lights ect and did you cover the pipe with a breather ?
