Should be fine then, let me know how easy it is to put the clutch pedal cover back on :think:
Easy, Spray the pedal and the back of the rubber with your G/F or wifes hair spray. This will lube the rubber for a minute or two whilst the hair spray is wet. Slide it on, once on the hair spray will dry out and act as a glue to keep the rubber in place.
Pretty decent drop on those springs mate. Seems more than 20mm. Also seems more than most of the 50/40 kits I've seen. Wonder what they would be like with Koni fsd dampers?
Thanks! Yeah I really like the drop, its not too low which is perfect and it handles much better now.
I would be interested in some Koni FSD Dampers.... :)
