Driver
52
UK
Hi,
Anybody know a way to relocate the start-stop button so that a 2-din headunit can be installed in an Ibiza 2014 FR model? I have found the part to move the hazard warning etc, but can't find any information about moving the auto start stop switch.
Driver
Can't you get a (blank?) switch for one of the other spare slots and somehow put a meaningful graphic on it?
I'm sure there's a few versions of the switch pack,see if your local dealer will look the part up and see what the different options are
photostream
Following intense googling, it seems a possible solution could be this. Anybody know the part number or where to get it from?
Hey Guys,
I have a Pre-Facelift 1.2TDI eco, the Start stop button is above the Cigarette lighter, not on the centre infront of the gear stick, i'm sure if you find a breaking yard with an Ecomotive you'll be able to nab the whole assembly, i've had my cigarette lighter out before and the start/stop button is literally just two wires so i'm sure it can be changed really easily
Hope this helps
Hey Guys,
Hope this helps
That's very helpful. Only if I had a part number, it would make locating it a lot easier.
Hi mate, I've been looking for the same thing! That part number is 6J0905218A for the small start/stop button. Bit of a pain that they didn't make a set of buttons with the start/stop below the hazards, but it looks like SEAT reserved that space for the Passenger airbag only.
May come in handy for you, there's a part code catalogue for the MK5 ibiza. It has every variation of items under the sun:
realoem.me/Seat/E/IB/2015/743/R/9/941/941050#10
Hope this helps, even if the post is slightly old!
-Josh
-Josh
Cheers mate. I’ve been trying to find a way for years, but haven’t got anywhere yet.
Hi,
Driver
Hi,
Driver
Hi,
I am trying to do the same thing with my FR. I have found the small stop start button to relocate it but my only issue is what wiring do I need to connect this?
Any advice would be great?
Hi,
Where are you going to relocate the start-stop button to?
From seeing where other people recommend I was planning on relocating it above the cigarette lighter. The panel in front of the gear stick only has one connection so I am trying to find a way to get the cables to the relocated button.
