Interesting I just filled up a few days ago. A blunt two weeks after the service and a week after the recall. I might call the seat garage and see what they say. But even the independent garage stated that my mpg should be higher than it is. A friend has a 1.9tdi and he's getting around 55-65mpg I ain't even getting that. I personally have noticed fuel consumption has been higher than normal.That update you are talking about is potentially the one following the emissions scandal where some owners reported after the update their mpg went down.
What i would do is the brim to brim method and work out for definite what the true mpg is as the trip computer could be way out.
The revs look higher than they should be, usually because it is completing an active regeneration but you dont have the smell to go with it so I wonder if it is stuck.
As I mentioned a while back - check your DPF - 1000rpm idle is a sign its doing/trying to do a regen.Current revs while idling. Also a previous journey around 40-45 miles journey a mixture of A and B roads and a couple of villages.
No black smoke.Yeah that sounds very low mpg indeed, are you getting any black smoke out the back when you accelerate hard?
