MjrSharpe
Astra VXR
Jun 18, 2012
497
Northern Ireland
Does anyone know if the rear bumper on the face lift fr is the same as the previous one in terms of fitting mudflaps because according to seat there are no rear flaps for any facelifted ibiza yt but if it's just a case of drilling a few holes in the wheels arch lining then that's OK.. Thanks for the help.
i have e mailed seat in the uk about this, the response was very poor, just saying it would be passed on to the relative department.
e mailing seat headquaters in spain was a little more helpful, in that they would look into it.
i have just fitted rear mudflaps to the new model fr [1.2tsi]
the top hole is in the correct position, the next one down is slightly off position, but a larger washer will grip the lip allright.
to attatch the bottom mounting, i drilled a small hole into the under edge of the bumber, and fixed it useing a small bolt.
result,a permanent solid job, with no visable signs of the bolt.
locate the top side screw first as this is in the correct position, do not tighten yet,
align the mud flap to its intended position,then fit the lower side screw, you will find that the screw hole in the actual mud flap is not in alignment,just put a large washer on the screw and tighten it up, this will grip the edge of the mud flap.
then tighten the top screw.
you will then have to drill a small hole, depending on the size of bolt you use, [i used a 5mm one] through the bumper lip from underneath, useing the mounting hole in the mud flap as guide.
2 months later, i recieved an e mail from my seat dealer informing me that seat acted upon this matter, and low and behold, they have produced the modified rear mudflaps for this model.
perhaps seat do listen to their customers after all!
Taken from the SEAT website -
Part Number: 6J0075101
Suitable for: IBIZA SC 2008 - 2012, IBIZA 5dr 2008 - 2012
Notes:
Please note this is not suitable for Ibiza Cupra, Bocanegra or FR or for vehicles fitted with a body kit
Part Number: 6J0075101A
Suitable for: IBIZA SC 2012 >, IBIZA 2012 >
Notes:
All I can do is raise the matter with SEAT UK, which I will !!
i am sorry, i do not have the part number, but assured that seat now produce rear mudflaps for the face lift fr range.
Does any one know correct part no for this i know its not for the fr but which one fots 101 or 101a thanks
