If it doesn't get regular use then it can start to smell (and can also harbour diseases like Legionnaires).
Can be cleaned with an AC bomb thing that you can buy from Halfords that you set off with the AC running at full blast and leave for 10 minutes or so.
i nearley wet myself when i read that
not true leionaires dissease is only found in water tank air conditioning systems that you find on large commercial buildings , not hemaptically sealed sytems like cars.
Tesco sell an airconditioning cleaner frm car plan cost £8 IIRC
As the heat increases outside, it is natural to reach for your air-conditioning unit to turn down the temperature inside. But should you? Research shows that although air conditioning in your home, car and workplace can aid asthma and allergy sufferers, neglected units can lead to all manner of serious health conditions, from persistent sinusitis to legionnaires' disease and hypersensitivity pneumonitis.
This article also implies the same:
http://www.autotrader.co.uk/articles/2010/06/cars/drivers-at-risk-of-legionnaires
legionaires dissease is a water born bacteria , thtas why in that autotrader link refers to washer fluid and not the airconditioning , old style buildings used cooling water towers as part of the air conditioning plant which harboured the dissease. car units are hermetically sealed and only use gas which is condensed into a vapor liquid but is sealed there is no fluid in the system just the condensate it extracts from the air moisture and dispenses on the road.
if we were at risk dont you think thee would be a warning on the car and something as part of the service intervals?
no one is an expert but some things are myths which are laughable
I've tried a few different makes of the bomb type cleaners. The halfords one works best and lasts the longest.
http://www.halfords.com/webapp/wcs/..._productId_224996_langId_-1_categoryId_165632
But the article DOES make reference to the air con in the same vein that is talks about bacteria in the washer bottle.
Additionally, the air conditioning system draws air through it which contains moisture and could easily condense inside the pipes (from my point point of view as someone with little knowledge of the inner workings of air conditioning systems). You may say it's laughable but to someone who doesn't know a huge amount about the bacteria or how it grows it is not.
As I said, my comment was based on information I have read previously on this forum and not empirical information. Consequently, my mistake is simply the result of someone else's misinterpretation of the empirical evidence.
