Moley RUFC
Up in the Lickeys........
Nov 20, 2006
1,232
Lickey,Worcs
Not a vast amount different but just enough for me, now to await a decent map for the diesel.
I've had a black mesh grille with badge (thanks Igor23!), LCR Splitter, black wing mirrors cover and a debadged rear! My fave little mod though is the jet black calipers with red SEAT decals, looks ace.
All fairly small things, but with a car as good as this theres no point me sticking a WRC style spoiler or dropping it on the ground!
Don't think the LCR spliter works at all...just looks stuck on. The mk2 leon it to wide for it. Think you should take it off and see if you can make cuts in it to weaken it at the sides allowing it stretch out to the profile of the front bumper. Ideally you would want to cut the splitter in half and then add a bit to follow the look of the bumper.
Other than that it looks spot on
I'm happy with the splitter, and i dont fancy messing with all them screws again. Know what you mean though, but its under the bonnet where i shall be concentrating from now on;)
I did paint them myself. Pretty straight forward although i would wait until its warmer now so the paint drys or use a hair dryer! The decals were very simple to do
are there any sensors etc. that you have to be careful of when painting.
Any other pointers or is it just a case of removing the pads, cleaning well and being careful with the paint?
That would look sweet. [B)]
I brought the black Foliatec paint from Halfords then brought some SEAT decals from Ebay for about 8 quid and away i went!
Easy
Hi mate,
If you got them from the same place i did you will also get the '' S '' Seat badge.
See below
FRONT
REAR
The rear calipers are as easy to paint with the wheels on to be honest. Just get a good size gap between the 18'' wheel spoke and paint. I did one with the wheel off and one with it on. The ''S'' badge looks good on the back but space is tight to stick it properly so i did it like above to make sure all the decal was stuck down.
I have cleaned and jet washed the car loads since and the decals look as if they have been just put on.
