Hi all, well I'm joining the club for boost leaks. I leak tested the car again today and what I couldn't hear before or what was less evident is now hissing away...under the inlet manifold.
So, here we are with my tyre pump and DIY boost leak tester made from a Vitamin C pot and the top of a spray can lid.
I blocked off the PCV pipe that goes back into the TIP with a bung of some sort that I found.
I pressurised the system through the top IC hose and heard a loud hissing side coming from the cam cover breather hose, this is what I found...
The hose isn't split but the single use OE clip had come loose and allowed air to leak around the hockey puck connector. I replaced the clip with a jubilee and all is well.
I again pressurised the system to a max of 10psi and I hear another loud hiss. This time it is coming from under the inlet manifold. I think I can rule out the hosr that connects to the N249 and also the FPR as I see no splits but lok here, bubbles coming from some sort of plastic Y-Piece of hose...
There is also a hiss coming from the same area, I believe from the same hose actually so I want to replace all of this. It connects from a nipple under the middle of the inlet manifold and then at the Y-Piece branches off to connect to one part of the cam cover breather hose and the other part shoots off round the back of the engine somewhere. What is this hose and what have you replaced yours with? I am guessing the the Y-Piece is a genuine part only, is it common for this to crack as it looks plastic to me and not rubber. There is also no clip around the area of the leak to suggest a connection to a rubber hose.
While I am at it I will also replace the vacuum hose for the N249 & also the FPR hose, which hoses did you use for this?
