My mk1 leon fr 1.8 20vt (PICTURES ADDED)
Adjay
383
Donegal,ireland
Nice and shined for the car show with my new number plate on also
Adjay
383
Donegal,ireland
Today i fitted the wiring for a amp and fitted a new jvc stereo, it was not easy at all. But i decided to make up my own wiring kit, i got 100amp power cable for the future for if im wanting to expand my sound system. Fitting through the car was quite tough i wanted it hidden under the engine bay.
So i unstalled it through the original gromet that the main wiring loom goes through, and then under the plastic wiring cover under the bonnet.
Then i brought it through to cabin then i fitted the main fuse behind the passenger side kick panel.
Adjay
383
Donegal,ireland
I got a friend to make me up two 5metre lengths of sheilded RCA cables with some lovely gold plated connectors only cost me €25.
Once i had fitted the wires i used some wire tidy to make it look neat under the trim.
Adjay
383
Donegal,ireland
Secondary air blanking plate so I can remove the air pump and egr removal also do n112 removal and n245 removal and coil pack cover and turbo boost pipes.
Three 10w 330ohm resistors needed.
First I had to trim them down and make them up.
Then shrink rap them.
Adjay
383
Donegal,ireland
Mine all done here is my engine bay.
I wanted to keep the evap system at the mo cos of nct but wanted to take out the metal pipes so I put a new silicone evap pipe in
Forge blanking plate.
Adjay
383
Donegal,ireland
My old motor back up for sale. On adverts.ie bit for some reason he is look for way more than its worth since nearly two years ago I sold it for €3800
