Bought This on Friday, with no mot n no tax, stunning car went for a drive ect, perfect I thought!
Today went down to my lock up, looked over it, high level brake light inop, taped over until I can be bothered fixed it,
Washer bottle empty, fill it up to find it all coming back out, the gromit from the pump missing, a trip to halfords and its all sorted, next up was inop indicator bulb on the osf, replaced bulb still inop noticed a random plug... Found the fog light plug in to inductor swapped them over and it's all sorted,
Slung in 15l of v power and the eml light comes on, shows the sai fault cleared it and its stayed off, hopefully now it's all ready to go and will pass!! Although airbag lights on hopefully getting vagcom tomorrow night to switch it off before the test on Tuesday,
Star proformance remap? Anyone got any experience with there maps? Considering getting motor werks to get it stage 1 mapped instead, all in all I'm happy with it, will see how I get on once it passes its mot ect,
Next on the list will be clutch n fly wheel? What's a decent upgrade on these?
Anyway here's the spec,
Engine-
1.8 20v turbo
Stage 1 remap by star performance
Jetex exhaust system
Jetex filter
Samco TIP & Hoses
Forge Cold side Dump valve relocation
Front mounted intercooler
Forge 007p dump valve
SAI removed
Aircon removed
Badger 5 Phelonic inlet gasket
Miller motorsport engine oil
Exterior & handling-
Audi 3.2 Brake conversion
Ferrodo racing pads Ds2500
Dot 4 Fluid
KW Variant 3 Coilovers
Standard 16'' wheels
Front upper and lower strut braces
Rear upper strut brace
10mm spacer front
15mm spacer rear
Metal pressed plates
Geo set up at Clark Motorsport!
Interior-
Fully stripped apart from door cards and roof lining.
Sparco sprint seats
Sabelt 4 point harness
Temp, oil pressure & boost gauges
OMP steering wheel
Engine-
1.8 20v turbo
Jetex filter
Samco TIP & Hoses
SAI removed
Aircon removed
Dot 4 Fluid
10mm spacer front
15mm spacer rear
Interior-
Sparco sprint seats
OMP steering wheel
