My new wee beastie - sti content
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
good day today
i started sanding my wheels yesterday dinner, on my car
so decided today to whip them off and get cracking,
here they are
IMG_3526 by cuprajake1, on Flickr
IMG_3523 by cuprajake1, on Flickr
IMG_3528 by cuprajake1, on Flickr
there a derivitive of the nissan gtr r35 wheel colour with added xirrilic pearl :) should sparkle pretty well in the sun
also my fog covers came in which you can see above too.
while the wheels were off i inspected the pads, fronts were pretty stuffed so got a set of mintex 1144 in there as a good friend rate ;)
jake
jake
Feb 2, 2003
2,666
rochdale
jake
jake
Feb 2, 2003
2,666
rochdale
Today did something about my seats, anyone who's been I a hawk knows that the seats are no longer the nice tight supportive seat they used to be, now I could and nearly did buy jdm version 9 seats, but there wrong for the car and also have no airbags.
So what to do.
Unzip the back of the seat
Then decided to remove it altogether, battery off and unclipped, and put on my bench
You need to take the side plastics off, couple of screws and a bolt
The seat covers use the normal plastic snaps so come off easy
Now my right lower bolster was starting to compress due to getting in/out etc so looked at that too
Once you have bit off the foam can lift off, this is the bit that rubs through
So I used a low density foam to cover it.
Then set about making new bolsters
The foam layout is hd and ld foams once I was happy I permanently attached them with duct tape.
Left side done right oem
Once the bottom had been done I moved to the upper back,
This has three springs along it. You can pulley these back and stretch them, this takes the push effect out of the seat. I also did this to the base.
I ran out of big pieces of foam so got a bit of new carpet underlay for the bolster.
I traced the black parts if the seats a d installed the foam
Then from the back of the seat I added son smaller hd packing around the rib area. I also took out the middle spring
Once you've sat in it and are happy build it back up and your done
The seat feels 100 times better.
jake
Feb 2, 2003
2,666
rochdale
Being 2.5 there very torquey and spool earlier than a 2.0.
I love them.
Oh btw I'm painting it white :)
Today I degreasers the car heavily.
I will continue to do so over the week, weekend is the start of the project hopefully.
Also removed the rear spoiler. Whcih being three piece I sikka flexed on, and broke one cap. So repair needed on that !
RickyD1992
Great looking scoob dude, you've done a fantastic job of cleaning it !
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Got some lovely closed block, alloy, 2.3 American EJ22 engines for when your 2.5 shits itself if you're interested?
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
The price (considering their rarity) is reasonable and they're regarded as the best bottom end for any scooby build.
They have the cylinder bore face of the block welded over then all the water jacket holes are drilled resulting in a rock solid bottom end which also helps preserve the head gaskets.
TBH the early 2.5 is pretty robust but the later 2.5 engines were the subject of much cost cutting which resulted in many different failures.
jake
Feb 2, 2003
2,666
rochdale
As far as I'm aware. The weak points are hg and ring land. Not heard of any bottom end issues.
The engine could come out, new hg, bolts n forged pistons and a safe 400bhp can be run. App
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
The hatchback impreza from 2008+ with the 2.5 has lots of issues and its all down to spending cuts in the materials.
Shite quality head gaskets and poor face machining
Weak blocks and crappy (play doh) rods
Brittle pistons and easily damaged bore liners
Oil drinking bottom ends and turbos
The list goes on.
We have 2 in at the moment with the above problems and finished off a 2007 forester STI import last week with failed gaskets, all on less than 50k.
jake
Feb 2, 2003
2,666
rochdale
Screen guy came about 11
Then made a start about half one,
This resulted lots if bits
And not so much on the car
The car itself is very clean, but it had a few wibbles, these ain't dents but small marks in the panel. So blocked them down and primed then along with the front bumper
That's how it stand now,
One pants bit. Both captive nuts in the n/s/r handle are spinning!!!
Big thanks to Chris for helping.
Tomorrow will see some colour :)
jake
Feb 2, 2003
2,666
rochdale
Well got quite a bit done today with the help of Chrisr and si who's works for us.
Got all four doors, both bumpers, scoop and roof vent painted.
The cars now fully stripped and prepped.
Stolen pics off Chris
Tomorrow the rest of the bits will be finished along with the shell.
Jake
jake
Feb 2, 2003
2,666
rochdale
Well me and Chris got to work around 10 and made a start.
All the bits are painted & so is the shell, I,ll let the pics do the talking
Parts stripped off the car awaiting prep,
In the booth ready for painting
Work in progress
Gun finish
Bonnet & Boot next
Done
Shell Flatted & Prep for painting
Getting the first coat on it
All done
Pics are all Chris. Lol. I've been lazy and just copied his post
Gotta say a huge thanks to Chris for all his help on the car,
Jake
